Katsuo
Nov 04, 2023Aspirant
ReadyNAS 214 - Not working after OS reinstall
Hi! I am in trouble with my ReadyNAS 214. Cannot log in / view the disks. Situation - I could not log-in after discontinuation of Ready cloud support. - I tired Recover a lost admin pass...
- Nov 18, 2023
I reset the router and now DHCP of LAN is working fine.
I am happily able to access my files.
Thanks to those who gave me advices!
Nov 05, 2023Guru - Experienced User
If rebooting doesn't solve the DHCP problem, then try doing another OS reinstall.
There shouldn't have been any issue with accessing the NAS after Netgear shut down ReadyCloud, as the admin account is purely local. So it is possible that something else went wrong at about the same time.
Just to get clarity - you are saying you did the OS reinstall from the front panel? Or did you possibly try to do a USB recovery?
Katsuo
Nov 07, 2023Aspirant
Stephen B,
Thanks. I did OS reinstall from the front panel.
I had actually done a couple times, but will try that again.
