macgupta
Apr 22, 2017Aspirant
ReadyNAS 214 - Volume data is syncing
What is this "volume data is syncing" process on newly formatted hard drives? and why is it stuck at 4.8%? Scenario - new diskless ReadyNAS 214 with previously used drives; followed the procedure of...
macgupta
While it is bad form to reply to my own email:
1. I tried shutting down the ReadyNAS from RAIDar. The LED display said shutting down, but it kept grinding away.
2. I finally did the 3 taps on the power button to shut the ReadyNAS down, and it shut down.
3. On restarting, now all the admin widgets show up on RAIDar and I'm able to use the web-browser interface.
4. The syncing is proceeding, it is now at 14.36% complete and the progress is regularly updating (just now 14.45% complete).
5. On the Admin Page --> Performance, the fan was on quiet, and ReadyNAS was running hot - the CPU was at 65C, and the disks were at 50C. I've changed the fan setting to Balanced, and now the disks are at 41-44C and the CPU is at 60C. I'm thinking until all the set-up is complete, I should run the fan at Cool.
As I type this, syncing is 14.96% complete.
- jak0lantashApr 22, 2017Mentor
The resync of the volume is a normal operation when creating a couple of replacing a failed drive. If you want to read on the topic:
https://raid.wiki.kernel.org/index.php/Initial_Array_Creation
- StephenBApr 23, 2017Guru - Experienced User
As jak0lantash says, the resync is normal. The operation can take quite a while (days) - it depends on the size and number of the disks.
What disks are you using?
That's reasonable. I'd switch it back to balanced when the balance is done.
