zeevi
Nov 30, 2020Tutor
ReadyNAS 214: Blinking backup light and NO access
Occassionally, my ReadyNAS 214 will disappear from my network. When I look at it, the Power light is on, the disk lights are on, and the backup light is slowly blinking (about once per second). RaidA...
Nov 30, 2020Guru - Experienced User
What apps do you have installed?
What firmware are you running?
FWIW, holding the power button down for 5+ seconds will normally forcibly power down the NAS. Did you do that, or just press it momentarily?
- zeeviNov 30, 2020Tutor
I have tried holding the power button for 5 seconds. I will confirm that the next time it occurs.
Do you know what the flashing backup LED means?
josef
