zeevi
Nov 30, 2020Tutor
ReadyNAS 214: Blinking backup light and NO access
Occassionally, my ReadyNAS 214 will disappear from my network. When I look at it, the Power light is on, the disk lights are on, and the backup light is slowly blinking (about once per second). RaidA...
Nov 30, 2020Guru - Experienced User
What apps do you have installed?
What firmware are you running?
FWIW, holding the power button down for 5+ seconds will normally forcibly power down the NAS. Did you do that, or just press it momentarily?
zeevi
Nov 30, 2020Tutor
I have tried holding the power button for 5 seconds. I will confirm that the next time it occurs.
Do you know what the flashing backup LED means?
josef
- StephenBNov 30, 2020Guru - Experienced User
No, I don't.
- zeeviDec 01, 2020Tutor
Thanks, StephenB.
Does anyone know what it means when the backup LED is flashing? (In particular, the unit is otherwise non-responsive.)
StephenB: how might I access the command console from SSH to look in whatever logs I might find to see what was going on?
- SandsharkDec 01, 2020Sensei
Did you enable SSH while you still had access to the GUI? If not, there is no way to use SSH.
If you did enable it, just open a Windows command prompt and type ssh root@nas-ip-address (using the actual address). But the unit may not be to the point that SSH is active.
Tech support mode and Telnet may be a solution. Can you boot to support mode via the boot menu? RAIDar should show you if you have successfully entered support mode.
