Aevans0001
Apr 19, 2021Tutor
Readynas 214 Factor Reset issue
Ok so last night I performed a factory reset on my Readynas 214. It warned me that I would lose all data and that I needed to backup everything. So after tI performed the reset, I noticed that t...
- Apr 19, 2021
Aevans0001 wrote:
1. What is it resyncing?
A factory default formats the disks, and does a completely clean installation. That includes recreating and syncing the RAID volume.
Note the resync process is needed (and takes the same amount of time) even when the file system is empty.
Aevans0001 wrote:
2. Is it safe to be putting things back on system before resyncing is complete?
Yes, but performance will be slower than usual, and the resync will take longer if you are loading data while it is running.
So if you want the fastest path to getting fully on line, you should probably wait for the resync to complete. If you want to get critical data back on line ASAP, then you can of course reload that data.
Aevans0001 wrote:
3. Why did my free space go fom around 37TB to 27TB?
Likely your disks are of unequal size. In that situation, there are multiple resyncs required to build the volume (one for each RAID group). You'll see the volume go back to it's original size when the last resync happens.
Apr 19, 2021Guru - Experienced User
