NAS-Bodger
Feb 05, 2017Aspirant
ReadyNAS 214 fails to recognise 4th drive
Please help! Have been trying for weeks to get my ReadyNAS 214 to recognise the 4th drive I inserted. For some reason, RAIDar could briefly see the 4th drive but the admin page will not. Feels li...
FramerV
Feb 06, 2017NETGEAR Employee Retired
Hi NAS-Bodger,
Welcome to the forums.
I would like to verify a few things regarding the ReadyNAS setup.
1. What firmware are you using?
2. What RAID level are you using?
3. Are you replacing a hard drive or are you expanding it?
4. When you see it on RAIDar, what does it say? (screenshots from the RAIDar and admin page might be best).
You could probably do a test on the new HDD using its own utility on your PC, just to make sure the HDD is healthy.
NAS-Bodger
Feb 07, 2017Aspirant
Thank for getting back to me FramerV,
The firmware I'm running is 6.6.1 and I'm using RAID 5 (X-RAID). I'm trying to expand - I have 3 drives in already and want to add a 4th. Screenshots attached.
Thanks,
NAS-Bodger
- StephenBFeb 07, 2017Guru - Experienced User
Is the new drive at least as large as the other three?
- NAS-BodgerFeb 07, 2017Aspirant
It's identical - they're all 2TB WD Red
- JennCFeb 07, 2017NETGEAR Employee Retired
Hello NAS-Bodger,,
No, do not remove the already existing one that is part of the RAID.
Maybe you could test the 4th disk with disk tools.
- NAS-BodgerFeb 08, 2017Aspirant
Hi JennC,
Yep, tried that. Did a comprehensive scan using Tech Tools and found no problems. I then wiped it and put it in the NAS - no joy. Then took it out and gave it a FAT-32 format using a a USB HDD enclosure and Disk Utility in OSX 10.12. I thought it might recognise it if it had some kind of format but that didn't work either :(
- StephenBFeb 08, 2017Guru - Experienced User
I am thinking you might have a failed SATA slot in the RN214.
Try shutting down, and removing the existing three disks (labeling by slot).
Then
- insert the problem in disk in slot 1
- do a factory default (page 61-62 here: http://www.downloads.netgear.com/files/GDC/READYNAS-100/ReadyNAS_%20OS6_Desktop_HM_EN.pdf)
- verify that the system sees the disk and does a clean factory install
If the system doesn't recognize the disk in the above steps, the it must be related to either the drive or the disk tray. That seems unlikely, given what you've done already.
If the install works, then
- shut down
- move the problem disk to slot 4
- power up
- test if the system boots.
If the boot fails with a no-disks indication, then it must be a bad slot.
