NAS-Bodger
Feb 05, 2017Aspirant
ReadyNAS 214 fails to recognise 4th drive
Please help! Have been trying for weeks to get my ReadyNAS 214 to recognise the 4th drive I inserted. For some reason, RAIDar could briefly see the 4th drive but the admin page will not. Feels li...
FramerV
Feb 06, 2017NETGEAR Employee Retired
Hi NAS-Bodger,
Welcome to the forums.
I would like to verify a few things regarding the ReadyNAS setup.
1. What firmware are you using?
2. What RAID level are you using?
3. Are you replacing a hard drive or are you expanding it?
4. When you see it on RAIDar, what does it say? (screenshots from the RAIDar and admin page might be best).
You could probably do a test on the new HDD using its own utility on your PC, just to make sure the HDD is healthy.
JennC
Feb 07, 2017NETGEAR Employee Retired
Hello NAS-Bodger,,
Could you check please on the admin page's System > Volumes? This should show the 4th disk with red mark while the other 3 in green.
- NAS-BodgerFeb 07, 2017Aspirant
Hi JennC,
All I see is three drives (see attachment). It it safe for me to remove the 3rd drive and put it in the 4th slot to see if it's the slot that's the problem?
