RobW_73
Jan 24, 2019Aspirant
ReadyNAS 214 keeps going offline.
Hi all,
Have had my ReadyNAS214 running for about 9 months. Over the past couple of months the RN214 keeps going offline. I can't recover and have to remove the AC power cable and re-boot it ba...
- Jan 24, 2019
Hi,
thanks for the reply. To clarify; F&P is short for File and Print.
Have just updated to the latest firmware and will monitor for a couple of days.
Thanks.
Rob.
RobW_73
Hi,
Thanks.
Rob.
Jan 24, 2019Guru - Experienced User
OS 6 doesn't have built-in support for connecting USB printers ( https://kb.netgear.com/7009/ReadyNAS-OS-6-USB-Port-use ).
Are you using an app for that, or are you really meaning only file storage.
