aks-2
Aug 08, 2023Apprentice
ReadyNas 214 new system fan / fan control
The fan in my RN214 is too lound once it gets going, so I took a chance at replacing it with a Noctua NF-A9. It usually works fine, the resported RPM in the dashboard is typically a bit lower than t...
schumaku
Aug 09, 2023Guru - Experienced User
Fans are always to loud as noise is involved. The fan system is designed to move a certain mass of air over time, to cover all possible (supported) conditions (environment temperature, installed storage blocks, maximum storage activity, ...).
Of course, because of the "press" and the "internet" is full with positive reports of this brand and model. There exist at least two models, some are paired with additional modules.
It's easy to make fans creating lower noise. Typical methods are lower RPMs, lower air flow.
The design RPM of the original fan is rated with 3200 RPM at nominal voltage of 12 V DC.https://www.delta-fan.com/Download/Spec/AFB0912HH.pdf . This inherits nominal noise in the 38 dB(A), to max 42 dB(A) by the pure fan. About what is considered the noise level in a silent library.
https://noctua.at/en/nf-a9-pwm/specification 4 pin, PWM speed regulation, nominal 2000 min^-1 at 12 V DC, with the low noise adapter (PWM signal) the RPM is lowered to 1550 min^-1, minimum 20% PWM duty cycle leads to (+/-20%) 400 RPM. Tempted to state this version is not for voltage based speed regulation.
https://noctua.at/en/nf-a9-flx/specification 3 pin, 1650, 1250 (Low-Noise Adaptor) and 1050 (Ultra-Low-Noise Adaptor) rpm. This is probably a voltage regulated unit, but far away from the RPM the device monitor does expect.
aks-2 wrote:
It usually works fine, the resported RPM in the dashboard is typically a bit lower than the stock fan, but the noise level is substantially quieter. The HDD temps increased slightly, but still typically <45C.
The RPM of these fans is very low - in fact ways below of what the hardware monitor does expect - it can happen easily that the speed is slightly reduced, by normal wear, by dust accommodated.
aks-2 wrote:
Any thoughts, ...
Install a fan matching the intended specs of the OEM fan to avoid any kind if negative issues.
aks-2 wrote:
...options for finer control over the fan speed (minimum voltage setting)?
None available - at least none ever made it to the community..
