Buxton
Mar 13, 2017Apprentice
ReadyNAS 214 Won't Restart/Shutdown
Hi, I have a bit of an odd problem and admittedly you can only reproduce it after doing something quite specific. So if I have a .mkv file in one Share and I connect to the NAS via Windows Explo...
Buxton
Hi, thanks for the reply it's 6.6.1. I did do a factory reset last time after I had to pull the power and it destroyed the array after not booting and it seems like it's just happened again.
Would you say if I can't restart it now then it would be worth an RMA, or maybe a firmware upgrade to beta?
- StephenBMar 13, 2017Guru - Experienced User
You could try contacting support and ask about an RMA.
One variation on the reset - if you have a scratch disk, you could power down, remove the drives (labeling by slot), and install the scratch disk. Then see if the scratch disk system behaves the same way.
