Buxton
Mar 13, 2017Apprentice
ReadyNAS 214 Won't Restart/Shutdown
Hi, I have a bit of an odd problem and admittedly you can only reproduce it after doing something quite specific. So if I have a .mkv file in one Share and I connect to the NAS via Windows Explo...
Buxton
I might give that a whirl with a spare I have actually, I did get the unit on Amazon so I'm sure they'd RMA quite happily if asked. I'll see what my testing throws up.
- mdgm-ntgrMar 13, 2017NETGEAR Employee Retired
Can you provide the full system logs (see the Sending Logs link in my sig)?
- BuxtonMar 13, 2017Apprentice
Hi,
I've just sent the logs in. I also just tried shutting down the system from within the UI which worked, so it seems that the issue with the unit locking up only occurs after transferring a file between Shares from Windows.
- mdgm-ntgrMar 14, 2017NETGEAR Employee Retired
The logs you sent are incomplete and missing the most important log the journal.
If you disable the anti-virus service and reboot does that make any difference?
