Buxton
Mar 13, 2017Apprentice
ReadyNAS 214 Won't Restart/Shutdown
Hi, I have a bit of an odd problem and admittedly you can only reproduce it after doing something quite specific. So if I have a .mkv file in one Share and I connect to the NAS via Windows Explo...
Skywalker
Mar 17, 2017NETGEAR Expert
Buxton, I've been trying to reproduce your issue, but I've been unable to so far. Are the two shares you are copying between on the same volume? What version of Windows are you using?
I've been testing with Windows 10, and with both shares on the same volume, copying a set of about 30 ~1-2GB files between shares.
