Gianlucam
Sep 10, 2021Tutor
ReadyNas 312 added larger drives (+syncinc) but volume is still small
Hi, I had two 8TB drive in my Readynas 312 but I was running out of space, so I bought two new 14TB drives (from the online compatibility list). shutdown the unit I removed one 8TB drive and repl...
- Sep 11, 2021
Gianlucam wrote: ...rebooted and synchronization is in progress, but the total volume is still 8TBThis is normal. The second synchronization happens in two steps, and you will see the expansion when the second step begins.
Your system will have two RAID groups - the original 2x8TB and a new 2x6TB group. These are concatenated into one volume, but as far as RAID management goes they are independent. When you replaced the first disk, only the original 2x8TB group could be synced. When you replaced the second disk, the system resyncs the 2x8TB group again, and then syncs the 2x6 TB group as the second step.
Sep 11, 2021Guru - Experienced User
