Arb1803's avatar
Arb1803
ReadyNas 312 Boot Problem
I am using my ReadyNas to automatically backup my family MacBooks at home (and for additional storage). It has 2x WD Black 4TB 3.5" HDD (7200rpm) discs in. Typically it just sits quietly on my network in the background. Periodically I check it and perform any updates etc. The other day I was unable to connect to it and then noticed one of the two disc lights flashing - sorry I am not technical in any way! The blue power light was on (not flashing). Because I was unable to login to it I decided to reboot it by holding down the power button. Since then, 24 hours have ellapsed and the ReadyNas seems to be still trying to reboot!!! The blue power light is flashing and the fan sounds like it's at max and has also remained on. Clearly this is not a good sign. I have three questions: 1) Is this situation fixable? 2) if so, what action should I take taking? 3) if it is not fixable, is there any way I can still try to recover the data from the discs - taking into account my limited technical knowledge. Any ideas would be most welcome.
  • StephenB's avatar
    Can you download RAIDar 6.5 and install in on a PC (or Mac)?  https://kb.netgear.com/20684/ReadyNAS-Downloads#raidar
    It should find your NAS on the network, and give you some status.  Let us know what it says (ideally attach a screenshot of RAIDar to your post).
    There is info on how to get a screenshot here: http://quickfics.facultyinnovate.utexas.edu/capture-screenshots-on-a-pc/ and https://www.itg.ias.edu/content/keyboard-shortcuts-capture-screen-shot-mac-os-x
    If you capture more than you need, you can crop it.  But please keep the full resolution, and store it as a PNG (not JPG). You attach it to the post using either the "Choose File" control underneath the post, or using the "photos" icon in the post toolbar.
    After that - RAIDar also has controls to get logs from the NAS and run diagnostics.  If those controls are active, try getting the logs first, and then run the diagnostics.
    • Arb1803's avatar
      Arb1803
      Thanks for such a prompt response Stephen. Okay... I have installed the new RAIDar. The status is saying: Management Service is Offline. The firmware is: 6.9.3. My problem now is that for me to get the logs etc. it needs my usual login credentials, which for some reason it is no longer accepting! I am definietely entering the correct credentials. Is there a limit to how many times I can enter them i.e. could it have locked me out? Or by moving to the new RAIDar, is there a new default password (I have tried admin/ password). Everything I enter just tells me Not a Valid Username or Password???
      • StephenB's avatar
        The default admin password is still password.
        One option is to try an OS reinstall from the boot menu - see pages 65-67 here: http://www.downloads.netgear.com/files/GDC/READYNAS-100/ReadyNAS_%20OS6_Desktop_HM_EN.pdf
        That should
        • partially reinstall the OS.  Data shouldn't be affected (neither should most settings).
        • The network will be reset to DHCP (automatic) with bonding off
        • Admin password will be reset to password
        • Volume quota (on the volume settings wheel) will be turned off
        If that doesn't restore admin access, you should consider using paid support (my.netgear.com).
ProSupport for Business
