jason92s
Jul 09, 2015Aspirant
ReadyNAS 312 Need Help Understanding Snapshots
We're about to pull the trigger on a ReadyNAS 312 with either two 2TB or 4TB drives. We have about 290GB of data files. Ideally we'd like to have daily snapshots, but I'm unsure how much data a snaps...
Jul 10, 2015Guru - Experienced User
I think "previous versions" is a very nice feature ReadyNAS feature, and perhaps under-publicized.
If you know what file you want to roll back, it is much faster/more convenient than browsing through a ton of snapshots.
- CLHatchJul 26, 2015Luminary
If you know what file you want to roll back, it is much faster/more convenient than browsing through a ton of snapshots.Unfortunately, seems the "Previous Versions" feature has been changed in Windows 10 (or maybe in Windows 8, not sure). They now have you specify a location to "back up" to for the previous versions. So the snapshots are no longer available through the Windows Previous Versions feature.
- OOM-9Jul 29, 2015NETGEAR ExpertI am not seeing that issue on my Windows 10 install.
Did you go into the share configuration on the ReadyNAS to enable the "Allow Snapshot Access"?
That button does two things:
1) mounts your snapshots to a folder so you can browse
2) allows the functionality for "Previous Versions" in windows.- CLHatchJul 29, 2015Luminary
2) allows the functionality for "Previous Versions" in windows.I'll need to verify this later, but pretty sure I did both, yes. Windows 8 through 10, they changed the Previous Versions to where it uses the File History option, where you specify a drive to store the previous versions to.
- Jun 06, 2017Retired_Member
