TechNewbie35's avatar
TechNewbie35
Follower
May 29, 2019
ReadyNAS 312 readyCloud for remote users
We have a ReadyNAS 312 for our business that we use with a shared folder that about 10 users use for working on files. We want to open a satellite office on the other coast and be able to give those ...
  • StephenB's avatar
    May 29, 2019
    Personally I'd look at deploying a VPN to fully connect the network on the two sites.  Then people in both offices would be able to access the NAS (and other resources like network printers).
    But ReadyCloud could be used - you set up the folks in the satellite office with ReadyCloud accounts (not local NAS accounts).  They'd install the ReadyCloud app on their PC, and use that to connect to the NAS using the ReadyCloud VPN.  There is no sync involved, since they are directly accessing the NAS share.  I suggest that you turn on ReadyCloud and use it yourself for a bit, and make sure the performance will meet your needs.
ProSupport for Business
