RPB123
Apr 14, 2021Aspirant
ReadyNas 312 Time Settings Issue
Hi All, I have an issue wtih the time on my ReadyNas device, I have put in a number of servers for it to sycrnise with including time-c.netgear.com, time-d.netgear.com,time-e.netgear.com but ...
- Apr 14, 2021
RPB123 wrote:
but it is always an hour behind my timezone in the UK (0:00 GMT).
Any ideas what could be causing this?
If you are using "Greenwich Mean Time" in the pulldown, you might want to switch to "Western European Time" instead. I don't think "Greenwich Mean Time" handles summer time.
RPB123 wrote:
is there a better netgear server to use for my area?
You can use any NTP server, including
- 0.uk.pool.ntp.org
- 1.uk.pool.ntp.org
- 2.uk.pool.ntp.org
- 3.uk.pool.ntp.org
Sandshark
Apr 15, 2021Sensei
By definition, GMT, aka Zulu Time, never goes on Summer Time, Daylight Savings Time, or whatever it's called in your country. Some countries and regions never change since makes no sense when you are close to the equator (and some say it never does), and change dates vary for those that do.
RPB123
Apr 15, 2021Aspirant
Thank you both, all sorted :)
