cpatterson
Feb 02, 2017Aspirant
ReadyNAS 312 Vertical Expansion - First Time
We needed to upgrade a client from their existing 2Tb Raid 1, to a 6Tb Raid 1. I verified that the WD Black 6Gbs were in the acceptable (compatible: http://kb.netgear.com/20641/ReadyNAS-Hard-Disk-Com...
- Feb 07, 2017
Just manually triggered the RAID array to expand to use the additional space on the disks. Once this is complete the volume should then expand.
Feb 02, 2017Guru - Experienced User
Sometimes the btrfs file system needs to be manually expanded - not sure why. There are some ssh commands you could try if you are willing.
Did you purchase between 1 June 2014 and 31 May 2016? If so, you have free lifetime chat support, which you might want to use.
Backing up the data, doing a factory default, and then restoring the data is another avenue.
I suggest PMing mdgm-ntgr, and seeing if he is willing to look at your logs.
- cpattersonFeb 03, 2017Aspirant
Thanks for the rapid response! I checked our records, and we purchased this unit in April of 2014 :smileysad: . So, no free chat for me! But, it sound like you've got the knowledge to assist, if you have the time and patience :) .
Sorry, I started yesterday, but had to run to another call. Reply again at your convenience, and let me know what information you need, and where I can start, please. Thanks for your assist!
- StephenBFeb 03, 2017Guru - Experienced User
I can point you to other posts, but I don't work for Netgear and can't really offer direct support - just advice.
No worries. I'll see if I can get a response from mdgm-ntgr. thanks :)
- Sep 06, 2016Retired_Member
