cpatterson
Feb 02, 2017Aspirant
ReadyNAS 312 Vertical Expansion - First Time
We needed to upgrade a client from their existing 2Tb Raid 1, to a 6Tb Raid 1. I verified that the WD Black 6Gbs were in the acceptable (compatible: http://kb.netgear.com/20641/ReadyNAS-Hard-Disk-Com...
- Feb 07, 2017
Just manually triggered the RAID array to expand to use the additional space on the disks. Once this is complete the volume should then expand.
Feb 03, 2017Guru - Experienced User
I can point you to other posts, but I don't work for Netgear and can't really offer direct support - just advice.
cpatterson
Feb 03, 2017Aspirant
No worries. I'll see if I can get a response from mdgm-ntgr. thanks :)
- aalexandrebetaFeb 05, 2017Master
It's easy first take your time and be patient!!!
312 that means only 2 HDD if I remember!
1 step for RAID 1 prepare your 2 new HDD
2 extract first HDD from the 1 st tray of the array and replace by the new one then put it back
Warning message will flash you'll go from dedundant to degraded, then after 5hrs around be back to redundant!
3 same thing for disk 2
Warning message will flash you'll go from dedundant to degraded, then after 5hrs around be back to redundant and then automatically it will expand the volume 5 extra hours!
voila
regards!
I forgot TAKE YOUR TUME BE PATIENT!
A friend of mine a complete jackass lost 4Tb by doing taking of all his disks thinking that the device will trun back his datas in the thin air!
The new disk must be new or if recycled Low level formated!
- cpattersonFeb 06, 2017Aspirant
thanks for the replies :) Unfortunately, the first part of the process you describe went cleanly as planned, but the second part (the expansion) still apears to be non-constructive. MDGM has been kind enough to reply to my PM, and I hope to get this resolved this week. I'll update here as we (he) progresses. Thanks!
- aalexandrebetaFeb 06, 2017Master
What is going on on your side?
- Sep 06, 2016Retired_Member
