cpatterson
Feb 02, 2017Aspirant
ReadyNAS 312 Vertical Expansion - First Time
We needed to upgrade a client from their existing 2Tb Raid 1, to a 6Tb Raid 1. I verified that the WD Black 6Gbs were in the acceptable (compatible: http://kb.netgear.com/20641/ReadyNAS-Hard-Disk-Com...
- Feb 07, 2017
Just manually triggered the RAID array to expand to use the additional space on the disks. Once this is complete the volume should then expand.
cpatterson
Feb 06, 2017Aspirant
thanks for the replies :) Unfortunately, the first part of the process you describe went cleanly as planned, but the second part (the expansion) still apears to be non-constructive. MDGM has been kind enough to reply to my PM, and I hope to get this resolved this week. I'll update here as we (he) progresses. Thanks!
aalexandrebeta
Feb 06, 2017Master
What is going on on your side?
- Sep 06, 2016Retired_Member
