cpatterson
Feb 02, 2017Aspirant
ReadyNAS 312 Vertical Expansion - First Time
We needed to upgrade a client from their existing 2Tb Raid 1, to a 6Tb Raid 1. I verified that the WD Black 6Gbs were in the acceptable (compatible: http://kb.netgear.com/20641/ReadyNAS-Hard-Disk-Com...
- Feb 07, 2017
Just manually triggered the RAID array to expand to use the additional space on the disks. Once this is complete the volume should then expand.
mdgm-ntgr
Feb 06, 2017NETGEAR Employee Retired
A resync is now taking place. The volume should then expand.
aalexandrebeta
Feb 07, 2017Master
BE PATIENT, the procedure is somewhat long!
NG nerds should warn users that it is taking quite some thours and to complete the procedure days!
From 8 to 14 To, it tokk me a week.
1 raid 1 array 4 to 6To
2x 1 raid 1 array 2 to 4 To!
- Sep 06, 2016Retired_Member
