cpatterson
Feb 02, 2017Aspirant
ReadyNAS 312 Vertical Expansion - First Time
We needed to upgrade a client from their existing 2Tb Raid 1, to a 6Tb Raid 1. I verified that the WD Black 6Gbs were in the acceptable (compatible: http://kb.netgear.com/20641/ReadyNAS-Hard-Disk-Com...
- Feb 07, 2017
Just manually triggered the RAID array to expand to use the additional space on the disks. Once this is complete the volume should then expand.
aalexandrebeta
Feb 07, 2017Master
BE PATIENT, the procedure is somewhat long!
NG nerds should warn users that it is taking quite some thours and to complete the procedure days!
From 8 to 14 To, it tokk me a week.
1 raid 1 array 4 to 6To
2x 1 raid 1 array 2 to 4 To!
cpatterson
Feb 07, 2017Aspirant
aalexandrebeta wrote:BE PATIENT, the procedure is somewhat long!
My problem wasn't patience waiting, it was that it wasn't doing anything. No resync, no expansion in progress, no nothing :) Fortunately, mdgm-ntgr is a lifesaver :)
- aalexandrebetaFeb 07, 2017Master
cpattersonSorry for not beeing as helpfull as I wwould like.
Congrats to NG nerds mdgm-ntgr and StephenB ! :) :) :)
I did my best!:(
- cpattersonFeb 07, 2017Aspirant
aalexandrebeta wrote:cpattersonSorry for not beeing as helpfull as I wwould like.
I did my best!:(
No worries, I have that problem on a regular basis heheh. Besides, I learned long ago to never ignore advice. You never know when it'll come in handy :)
- StephenBFeb 07, 2017Guru - Experienced User
mdgm-ntgr is the lifesaver in this case (as in many others).
By the way my bad for murdering the English langage sometimes! :) !
- Sep 06, 2016Retired_Member
