DaPan
Nov 06, 2023Aspirant
Readynas 3138 Not booting (LED-Language?)
Our Readynas 3138 stopped working yesterday. It was still running LED looked normal but I couldnt access it via IP. I had to force a shut down since gaceful wasnt working. After that it wouldnt boot ...
Nov 06, 2023Guru - Experienced User
DaPan wrote:
Our Readynas 3138 stopped working yesterday. It was still running LED looked normal but I couldnt access it via IP. I had to force a shut down since gaceful wasnt working. After that it wouldnt boot up but shows the LED-Pattern attached:
no status leds
hd1 none
hd2 green and red
hd3 green
hd4 red
The LED status is described on pages 41-41 here:
Red and green isn't listed, so something is odd with hd2.
Is RAIDar finding the NAS?
- DaPanNov 06, 2023Aspirant
Raidar doenst find the NAS. I found that It's rebooting after a while, but instantly stays like shown in the photo. power / health / UI /LAN- LED are off, but fans are spinning.
- StephenBNov 06, 2023Guru - Experienced User
Maybe try powering down and removing the disks (labeling by slot). Then power up diskless, and see if RAIDar finds the NAS.
