OdetteJaycock
Nov 24, 2017Aspirant
ReadyNas 314 - Is it possbile to backup to two devices without setting up seperate backup jobs?
Before I continue I'm unable to select that the device in question is a Netgear ReadyNas 314 and not a router. Drop down is broken. What I want to achieve is the following - back up to two usb atta...
Nov 28, 2017Guru - Experienced User
Lots of folks here have complained about USB naming, but so far Netgear hasn't addressed it.
Can you select the USB port as the destination of the backup job?
- OdetteJaycockNov 28, 2017Aspirant
Hi
Thanks for that. No I didn't want to change anything until someone had replied to my question as the backup is working with one backup device.
We'll have to manually change the backup location eah time the backup device is changed from what you are saying then?
- StephenBNov 28, 2017Guru - Experienced User
Well, I believe if you changed the destination to the USB port that would work. You could of course use two different backup jobs that are identical except for the destination path.
Another thought is that you could create a share on one of the USB drives, and create the same folder on the other. Enable rsync for the share, and then use rsync (127.0.0.1 has the destination host, with the folder name as the path).
There are certainly other users here who have dealt with this, hopefully they will chime in. Personally I back up my main NAS to other NAS, so it's not something I need to struggle with.
- OdetteJaycockDec 04, 2017Aspirant
Hi
The second backup device was attached and the backup ran through successfully but the original backup is now failing saying it can't find the destination even though I can clearly browse to the folder locations.
I've seen an option in the "Cloud" tab in the main Netgear login page to use Dropbox which is an option for us as we have ample space and our data is only around 15GB in size. Do you have any experience of using Dropbox as a backup solution to get a copy of the data offsite?
Thanks
