siddadav
Dec 11, 2016Aspirant
readynas 314 (6.6.0) services not starting
i recently upgraded to 6.6.0 (from 6.5.2) and noticed i was unable to gain access to my files via readynasDNLA. i logged in and went to the services section under settings, and the only services that...
- Dec 13, 2016
This should be fixed now. Can you check? There was a damaged config file (most likely as a result of the OS partition becoming full).
BrendanM
Dec 13, 2016NETGEAR Expert
siddadav
Dec 13, 2016Aspirant
Hi,
I will check when I get home later, Thank you.
Also do you know what caused the OS partition to become full? was it an App that caused it (just so I can make sure it never happens again).
Regards
Dave
- mdgm-ntgrDec 13, 2016NETGEAR Employee Retired
You filled your 4GB root volume (aka OS partition) with
1. MySQL database(s) - I moved this to the data volume and created a symlink
2. XBMC folder under /root - I also moved this to the data volume and created a symlink
