siddadav
Dec 11, 2016Aspirant
readynas 314 (6.6.0) services not starting
i recently upgraded to 6.6.0 (from 6.5.2) and noticed i was unable to gain access to my files via readynasDNLA. i logged in and went to the services section under settings, and the only services that...
- Dec 13, 2016
This should be fixed now. Can you check? There was a damaged config file (most likely as a result of the OS partition becoming full).
siddadav
Dec 13, 2016Aspirant
Hi, I have checked the services and I am now able to start and stop services. Thank you so much for all your help.
- FramerVDec 13, 2016NETGEAR Employee Retired
Hi siddadav,
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
