aginstallations
Feb 14, 2017Aspirant
ReadyNas 314: Always going offline!
Dear all, I am writing here a I have a serious issue with my ReadyNAS 314. Tis device is hard wired to a local router in our office with x4 work stations (laptops) connecting to it through wifi c...
mdgm-ntgr
Feb 14, 2017NETGEAR Employee Retired
Do you use anti-virus? If so, try disabling it and see if that makes a difference. There have been some anti-virus fixes that systems will automatically download but there are more fixes coming in the next firmware release.
Are you able to download your logs (see the Sending Logs link in my sig) and send those in?
aginstallations
Hi,
Thanks for your reply. On the x4 laptops I do not have unti-virus I only use windows deffender. I use antivirus on the ReadyNAS. I will diactivate it and will see from there.
