aginstallations
Feb 14, 2017Aspirant
ReadyNas 314: Always going offline!
Dear all, I am writing here a I have a serious issue with my ReadyNAS 314. Tis device is hard wired to a local router in our office with x4 work stations (laptops) connecting to it through wifi c...
Feb 27, 2017Guru - Experienced User
Check to see if ipv6 is enabled on the NAS - if it is, try disabling it.
Do you use NIC bonding (both ethernet ports of the NAS)? If so, try removing one cable as well.
aginstallations
Feb 27, 2017Aspirant
Hi,
No I am using IPv4 and only one networkcard.
- StephenBFeb 27, 2017Guru - Experienced User
aginstallations wrote:
Hi,
Good to know. IPv6 is enabled by default on NAS though, and win10 will often try to use linklocal ipv6. So you might still confirm that ipv6 is disabled in the NAS network configuration.
-What apps (if any) do you have installed?
-Are you using the ReadyCloud app on those PCs, or are you accessing the NAS directly?
-Try downloading the log zip from the NAS, and look at the statistics for RX and TX (feel free to post them here if you aren't clear on what they mean). They are in network_settings.log.
- aginstallationsFeb 27, 2017Aspirant
Hi,
I disabled IPv6 and am using only IPv4 static only. Will see how that goes and if nothing is solved will check the logs.
- aginstallationsFeb 28, 2017Aspirant
Hi,
Nothing solved! Please download the logs from the link below maybe you'll figure out something. I hope for a new firmware update very soon, maybe it'll fix the issue!
