matt1
Jun 05, 2020Aspirant
ReadyNAS 314 hard drive tray
Hello! I have a ReadyNAS RN314 storage device. I am trying to swap out the 4TB drives for 8TB. I have one problem though. The clips in the hard drive trays do not match the hole positioning on the ne...
- Jun 05, 2020
That's them.
Jun 05, 2020Guru - Experienced User
You need to remove the plastic mounting brackets from the disk tray and then screw the drive to the bottom. The needed screws should have been shipped with your NAS, so hopefully you have still them.
It is likely that only one pair of mount points on the bottom of the drives will align with the holes in the disk tray. But that is enough to secure the drive.
- matt1Jun 05, 2020Aspirant
I am sure I don't have the screws anymore. I can surely buy extras though. Do you by chance know the screw size/type/spec?
- SandsharkJun 05, 2020Sensei
The best source for screws is to use ones designed for Supermicro servers with 3.5" drives. You can buy a bag of 100 from Amazon, as well as others.
You will be unable to find appropriate screws in a hardware store. The pitch on the countersink is much more shallow than standard and using anything else will prevent the tray from being mounted.
I bought these thinking they were right:
Should I be good with those?
