matt1
Jun 05, 2020Aspirant
ReadyNAS 314 hard drive tray
Hello! I have a ReadyNAS RN314 storage device. I am trying to swap out the 4TB drives for 8TB. I have one problem though. The clips in the hard drive trays do not match the hole positioning on the ne...
- Jun 05, 2020
That's them.
matt1
I am sure I don't have the screws anymore. I can surely buy extras though. Do you by chance know the screw size/type/spec?
Sandshark
Jun 05, 2020Sensei
The best source for screws is to use ones designed for Supermicro servers with 3.5" drives. You can buy a bag of 100 from Amazon, as well as others.
You will be unable to find appropriate screws in a hardware store. The pitch on the countersink is much more shallow than standard and using anything else will prevent the tray from being mounted.
