matt1
Jun 05, 2020Aspirant
ReadyNAS 314 hard drive tray
Hello! I have a ReadyNAS RN314 storage device. I am trying to swap out the 4TB drives for 8TB. I have one problem though. The clips in the hard drive trays do not match the hole positioning on the ne...
- Jun 05, 2020
That's them.
matt1
I bought these thinking they were right:
Should I be good with those?
Sandshark
Jun 05, 2020Sensei
That's them.
- matt1Jun 05, 2020Aspirant
Thanks! Is there an article I can see that shows how to pull those plastic liners out and remove them from the tray? I examined mine and can find any tabs to push that release it from the tray entirely.
- StephenBJun 05, 2020Guru - Experienced User
This gives you what you need. Once the plastic mount is released, you just pull it out of the back of the tray. Save it! - future disks you use might be able to use it.
