kalpsr
Jul 14, 2022Aspirant
Readynas 31400 Booting Issue
I have one Readynas 31400 running with 4 Seagate HDDs (2Tb each). All HDDs are of model ST2000VX008-2E3164. Every time I boot it, booting process is being stuck on Booting.... (4 Dots). After Hard...
- Jul 15, 2022
kalpsr wrote:
Also, have you tried just waiting (perhaps overnight) and see if the system eventually completes the boot?
-> I kept it ON yesterday night, but it did not boot.
I suspect the best plan is to offload the data, do a factory default, rebuild the NAS, and then restore the data from backup.
Jul 14, 2022Guru - Experienced User
After Hard Reboot it boots again successfully.
How are you shutting it down?
kalpsr
By pressing power switch only.
