kalpsr
Jul 14, 2022Aspirant
Readynas 31400 Booting Issue
I have one Readynas 31400 running with 4 Seagate HDDs (2Tb each). All HDDs are of model ST2000VX008-2E3164. Every time I boot it, booting process is being stuck on Booting.... (4 Dots). After Hard...
- Jul 15, 2022
kalpsr wrote:
Also, have you tried just waiting (perhaps overnight) and see if the system eventually completes the boot?
-> I kept it ON yesterday night, but it did not boot.
I suspect the best plan is to offload the data, do a factory default, rebuild the NAS, and then restore the data from backup.
kalpsr
By pressing power switch only.
Jul 14, 2022Guru - Experienced User
forced shutdown or preferred? See 72-73 here: https://www.downloads.netgear.com/files/GDC/READYNAS-100/ReadyNAS_%20OS6_Desktop_HM_EN.pdf
Also, do you see the same behavior if you shut down from the web ui?
- kalpsrJul 14, 2022Aspirant
Yes. I am doing the preferred shutdown only. But first time when it is being stuck, I am doing Force Shutdown because at that time network service is also not started. Also the problem occurs if I am doing shutdown through Web UI. Attached image for your reference.
- StephenBJul 14, 2022Guru - Experienced User
If you use the "read-only" boot option, does anything change?
I tried following steps :
Changed boot option to Read Only from Boot Menu
Result : Booting Normal
Power Off with Power Button
Started again
Started again
Result : Booting stuck again
