kalpsr
May 25, 2023Aspirant
Readynas 31400 Booting Issue
https://community.netgear.com/t5/Using-your-ReadyNAS-in-Business/Readynas-31400-Booting-Issue/m-p/2240900#M196804 replying to this after long time. I have done factory reset, OS Re-install also ...
AnishaA
May 26, 2023NETGEAR Employee Retired
Hello kalpsr ,
And welcome to the NETGEAR Community! 🙂
Attach the screenshot of the error you are getting and please tell the date of purchase of your NAS device.
Also, download the logs and attach them we will check what causes this issue.'
Have a lovely day,
Anisha A
Netgear Team
- kalpsrMay 26, 2023Aspirant
please guide how to attach the logs here because it is allowing only image or pdf files for attachments.
purchase date is somewhere in 2020.
- StephenBMay 26, 2023Guru - Experienced User
They'll want the entire log zip file. There is some privacy leakage, so it is best to send a private message ( PM) to AnishaA using the envelope icon in the upper right of the forum page.
Upload the zip to cloud storage (dropbox, google drive, etc), and then put a download link in the PM.
check your PM for details i have sent you.
- AnishaAMay 29, 2023NETGEAR Employee Retired
Hello kalpsr,
From the logs, it seems fine, and could not find any particular error for this issue. Need to investigate the issue deeper.
If you are falling under warranty I would suggest you open a support ticket case.
We will debug the issue and provide a possible solution.
Have a lovely day,
Anisha A
Netgear Team- kalpsrMay 29, 2023Aspirant
Warranty is expired for this NAS.
If you can give any other solution then please tell me.
Thanks in advance.
