kalpsr
May 25, 2023Aspirant
Readynas 31400 Booting Issue
https://community.netgear.com/t5/Using-your-ReadyNAS-in-Business/Readynas-31400-Booting-Issue/m-p/2240900#M196804 replying to this after long time. I have done factory reset, OS Re-install also ...
kalpsr
May 26, 2023Aspirant
check your PM for details i have sent you.
AnishaA
May 29, 2023NETGEAR Employee Retired
Hello kalpsr,
From the logs, it seems fine, and could not find any particular error for this issue. Need to investigate the issue deeper.
If you are falling under warranty I would suggest you open a support ticket case.
We will debug the issue and provide a possible solution.
Have a lovely day,
Anisha A
Netgear Team
- kalpsrMay 29, 2023Aspirant
Warranty is expired for this NAS.
If you can give any other solution then please tell me.
Thanks in advance.
