kalpsr
May 25, 2023Aspirant
Readynas 31400 Booting Issue
https://community.netgear.com/t5/Using-your-ReadyNAS-in-Business/Readynas-31400-Booting-Issue/m-p/2240900#M196804 replying to this after long time. I have done factory reset, OS Re-install also ...
May 29, 2023Guru - Experienced User
kalpsr wrote:
When I start the NAS first time, it is being stuck at Booting...
Then I do power off and start it again, it will boot normally.
Please provide some other solution.
Does this happen every single time you power up the NAS?
Have you ever seen it happen when you simply restart it (leaving it powered)?
Have you tried running the diagnostics from RAIDar?
- kalpsrMay 29, 2023Aspirant
As I observed, It is happening when the NAS is powered of without normal shutdown.
No. Issue is not happening when doing normal shutdown and restart.
Ran the test. Showing not any error.
- StephenBMay 29, 2023Guru - Experienced User
kalpsr wrote:As I observed, It is happening when the NAS is powered off without normal shutdown.
I don't see anything about how the NAS was shutdown before the failure to boot, and I don't see anything that says whether this happens 100% of the time.
I am asking this: When you power down the NAS with the preferred shutdown, does it always fail to fully boot when you start it up again? Or does it sometimes boot normally?
Yes always, with Booting... message only.
Then i will have to power off manually by pressing power button.
Once in a while it boots normally.
