kalpsr
May 26, 2023Aspirant
Readynas 31400 Booting Issue
https://community.netgear.com/t5/Using-your-ReadyNAS-in-Business/Readynas-31400-Booting-Issue/m-p/2240900#M196804 replying to this after long time. I have done factory reset, OS Re-install also ...
kalpsr
May 29, 2023Aspirant
When you power down the NAS with the preferred shutdown, does it always fail to fully boot when you start it up again?
Yes always, with Booting... message only.
Then i will have to power off manually by pressing power button.
Or does it sometimes boot normally?
Once in a while it boots normally.
May 29, 2023Guru - Experienced User
Also, can you connect the NAS hdmi port to a monitor before you boot it up? There might be some clues on the screen if you do that.
- kalpsrMay 30, 2023Aspirant
NAS Display when no boot
HDMI Display when no boot
HMDI Display when it boots successfully.
- StephenBMay 30, 2023Guru - Experienced User
So no prompt at all on the HDMI screen, and no disk activity lights lit when the problem occurs?
-> Only one cursor blinks.
-> All Disk Led off.
