kalpsr
May 26, 2023Aspirant
Readynas 31400 Booting Issue
https://community.netgear.com/t5/Using-your-ReadyNAS-in-Business/Readynas-31400-Booting-Issue/m-p/2240900#M196804 replying to this after long time. I have done factory reset, OS Re-install also ...
May 29, 2023Guru - Experienced User
Also, can you connect the NAS hdmi port to a monitor before you boot it up? There might be some clues on the screen if you do that.
kalpsr
May 30, 2023Aspirant
NAS Display when no boot
HDMI Display when no boot
HMDI Display when it boots successfully.
- StephenBMay 30, 2023Guru - Experienced User
So no prompt at all on the HDMI screen, and no disk activity lights lit when the problem occurs?
- kalpsrMay 30, 2023Aspirant
-> Only one cursor blinks.
-> All Disk Led off.
Definitely an odd problem. I'm tagging Sandshark to get his thoughts.
I'm guessing that the system isn't getting past POST (though it is odd that the LCD shows "booting" if that is the case).
When you power down the system, is it still connected to mains power? Or is that turned off? If it is connected to mains power, have you tried unplugging it for a while (~15 minutes or so), and then see if it boots normally?
