ro53ben
Dec 14, 2016Aspirant
ReadyNAS 316 - file system read only? Unusable #27793592
(not sure I logged this under the right RN model code, it's a 6-bay 316 but unable to confirm the code)
I've been running a 316 without fault for many years (I was jaffacake here but only accou...
Dec 14, 2016Guru - Experienced User
Looks like your system is mounted read-only - likely it detected a problem.
You probably should contact netgear support. BTW, if you purchased between June 1 2014 and 31 May 2016 then you have lifetime free chat support.
- ro53benDec 14, 2016Aspirant
Looks like I purchased in April 2014 - guess that doesn't count?
Struggling to find any US support at all here, keeps redirecting me to US and to sign-up in dollars.
Anybody know how to contact UK support? Or any ideas how to fix the problem? Everything seems fine, it's just gone read-only without apparent reason.- ro53benDec 14, 2016Aspirant
Looks like, as we thought, my support has expired. Being offered an annual support contract for £159 - is this normal? The US support seemed to have a $49 pay per incident?
Is there no way just to make this volume read/write?
