ro53ben
Dec 14, 2016Aspirant
ReadyNAS 316 - file system read only? Unusable #27793592
(not sure I logged this under the right RN model code, it's a 6-bay 316 but unable to confirm the code)
I've been running a 316 without fault for many years (I was jaffacake here but only accou...
Dec 14, 2016Guru - Experienced User
Looks like your system is mounted read-only - likely it detected a problem.
You probably should contact netgear support. BTW, if you purchased between June 1 2014 and 31 May 2016 then you have lifetime free chat support.
ro53ben
Looks like I purchased in April 2014 - guess that doesn't count?
