aalexandrebeta
Jun 25, 2016Master
Readynas 316 6.5.1 fan threshold below speed
6.5.0 was great for that matter. 6.5.1 turned a good new feature into a mess can't go up to 800 rpm! URGENT FIX IS NEEDED HOT SUMMER TIME her without AC!
- Jul 06, 2016
Hi aalexandrebeta,
Thanks for the feedback. You may update this thread if the problem persist or if you get other suggestions from support.
Kind regards,
JennC
Jun 29, 2016NETGEAR Employee Retired
Hello aalexandrebeta,
Please contact support center to report this, you have lifetime CHAT support for your ReadyNAS 316.
