aalexandrebeta
Jun 25, 2016Master
Readynas 316 6.5.1 fan threshold below speed
6.5.0 was great for that matter. 6.5.1 turned a good new feature into a mess can't go up to 800 rpm! URGENT FIX IS NEEDED HOT SUMMER TIME her without AC!
- Jul 06, 2016
Hi aalexandrebeta,
Thanks for the feedback. You may update this thread if the problem persist or if you get other suggestions from support.
Kind regards,
JennC
Jul 02, 2016NETGEAR Employee Retired
Hello aalexandrebeta,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accept as Solution” so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
- aalexandrebetaJul 06, 2016Master
I don't know what happened but after 2 days where the NAS didn't work properly, the fan speed seems to be OK now!
I sent a request to the support.
Thanks.
- BrianL2Jul 06, 2016NETGEAR Employee Retired
Hi aalexandrebeta,
Kind regards,
- aalexandrebetaJul 15, 2016Master
The situation is solved after 4 reboots don't know the issue!
