aalexandrebeta
Jun 25, 2016Master
Readynas 316 6.5.1 fan threshold below speed
6.5.0 was great for that matter. 6.5.1 turned a good new feature into a mess can't go up to 800 rpm! URGENT FIX IS NEEDED HOT SUMMER TIME her without AC!
- Jul 06, 2016
Hi aalexandrebeta,
Thanks for the feedback. You may update this thread if the problem persist or if you get other suggestions from support.
Kind regards,
aalexandrebeta
Jul 06, 2016Master
I don't know what happened but after 2 days where the NAS didn't work properly, the fan speed seems to be OK now!
I sent a request to the support.
Thanks.
BrianL2
Jul 06, 2016NETGEAR Employee Retired
Hi aalexandrebeta,
Kind regards,
