ItsPeter
Dec 25, 2018Star
ReadyNAS 316 ATA errors during data reshaping / resync
About 36 hours ago I replaced an ST4000VN000 (4TB) with an ST8000VN0022 (8TB) in my ReadyNAS 316 (Firmware 6.9.2). 4TB drive had not failed, just a pre-emptive swap, it was 4.5 years old, and I also ...
Marc_V
Dec 26, 2018NETGEAR Employee Retired
Hi ItsPeter
Welcome to the Community!
ATA errors can also be caused by the chassis not only the disk and if the ATA error is increasing then it should be taken care of the soonest.
You may want to check if it's the disk that is failing by removing it on your NAS and connecting it to your PC and use Seagate tool to test the drive. IMO, if you have any spare 8TB drive to use as replacement then that might be better but if it still causes for ATA errors then contacting Support is more advisable.
Your RN316 has 5 year Hardware warranty and if were purchased between June 1, 2014 and May 31, 2016 then Lifetime Chat Support is available for you. I would suggest logging in to my.netgear.com to create case and get Support to assist you.
Hope this helps!
Happy Holidays!
Regards
- StephenBDec 26, 2018Guru - Experienced User
Personally I'd be more concerned about the uncorrectable errors on the same drive. If that's a new drive, I'd exchange it.
Though the ATA errors might be a side effect of the same failure that is giving you the uncorrectable errors.
- ItsPeterDec 27, 2018Star
Thanks for the replies. The drive is not "new", but it is still under warranty. It has been in the unit under a year, it was probably sitting here on standby up to 6 months before that (I buy a new drive every time a drive goes into the unit, so there's always an unused spare here). I doubt the NAS itself is still under any warranty, but I'll check the purchase dates.
Sounds like no one has any insight into this scenario specifically (other than the drive might just in fact be bad), so I've decided to let it go for a bit as an experiment (all the data is mirrored to another NAS as well, so worst case I've just got to rebuild this one if it all goes pear shaped).
I suspect the drive is not bad, and the errors were just a resync anomoly, so I'll leave it a few weeks and see if further errors show up. If nothing after a month or so, I'll pull the drive and swap it anyway, and run the diagnostic tools on it. Whatever the outcomes, I'll post them back here.
