yeapstab
Dec 14, 2017Aspirant
ReadyNAS 316 slow connection
Hi all hoping to see if anyone else is experiencing a similar issue or has in the past. When I make a connection to the ReadyNAS via wired LAN it is taking up to 30-40 seconds from login to the syste...
mdgm-ntgr
Dec 14, 2017NETGEAR Employee Retired
Which apps do you have installed?
How full is your root volume?
Any problems showing in the diagnostics log from RAIDar?
Does your network_settings log show many errors?
yeapstab
Plex
data 3.24 TB
Snapshots: 16.21GB
Free Sapce 2.19 TB
Type raid 5
Successfully completed diagnostics System
No errors found.
Logs
No errors found.
eth1 Link encap:Ethernet HWaddr
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:3754525 errors:0 dropped:0 overruns:0 frame:0
TX packets:380028 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:5541874611 (5.1 GiB) TX bytes:134224335 (128.0 MiB)
Interrupt:19 Memory:fe700000-fe720000
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:359720 errors:0 dropped:0 overruns:0 frame:0
TX packets:359720 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:136367451 (130.0 MiB) TX bytes:136367451 (130.0 MiB)
- mdgm-ntgrDec 14, 2017NETGEAR Employee Retired
I meant the 4GB root volume on the disks that stores the OS, your settings etc. You can see this in e.g. btrfs.log
- yeapstabDec 14, 2017Aspirant
Let me know if this looks correct.
Label: '43f65f50:root' uuid: 1362353c-c2b3-4b53-aeff-db260d3cc490
Total devices 1 FS bytes used 1023.79MiB
devid 1 size 4.00GiB used 4.00GiB path /dev/md0- yeapstabDec 14, 2017Aspirant
At this point I am unable to download any large file from the NAS. A 2.5 MB mp3 take about 2 minutes to download.
