R2dTOO
Jan 12, 2019Guide
Slow internet when connected to Wifi
I just got AT&T 1000Mbps fiber internet, as well as an R7000 Nighthawk router. The AT&T RG is in passthrough mode, and the Nighthawk is in router mode. Nighthawk is running firmware version 1.0.9.60_10.2.60.
When I connect my laptop via ethernet to the Nighthawks, I'm getting 900Mbps or higher download. However, when i connect via wifi, I'm luck if I break 100Mbps (usually, it's in the 60s). The only think I've changed from the efault Netgear setup is I did enable Smart Connect.
Does anyone know what I can do to fix this?
- microchip8Master
Disable smart connect, lots of issues with it
on which band are you testing? 2.4 or 5 GHz?
- R2dTOOGuideOK. I disabled Smart Connect, and speeds went up a little. I'm now getting around 150-175. I'm testing from both my phone (Samsung Galaxy S9), and my laptop. Before I put the Router in place, and just tested with the AT&T gateway, I would get 400-500+ on wireless.
- IrvSpMaster
Are you running two wireless networks???
Define what you mean by " just tested with the AT&T gateway"?
- IrvSpMaster
Besides turning off Smart Connect, did you ever have faster wireless speeds? If so, how fast, on what device and what band?
What was your ISP speed before? 100Mbps or slower? Did/do you have QoS enabled? If so, turn it off.
