Nakhodka
Nov 22, 2017Aspirant
Readynas 3200 firmware to 6.9.0
I have a ReadyNAS 3200 RN12P0000 with 12HDDx2Tb, installed version 4.2.31. Can I install os 6.9.0 and how to do it correctly if possible? And what drives are better to use, and then with theseSeaga...
- Nov 23, 2017
You can, and instructions are outlined here: https://community.netgear.com/t5/Using-your-ReadyNAS/Ultra-6-OS-Upgrade-from-4-2-30-to-OS-6/m-p/1181060/highlight/true#M120724
In my opinion, you should be using enterprise-class drives in a 12-bay NAS. For instance WDC Red Pro, WDC Gold, or Seagate Ironwolf Pro.
Nov 23, 2017Guru - Experienced User
Nakhodka
Nov 23, 2017Aspirant
My friend, Thank you very much !!! I did it on your advice, it worked the first time and now works on OS 6.9.0
