JIT
Feb 20, 2013Follower
Readynas 3200 v1 Locks up under load
Firmware: 4.2.22 Windows 2008 R2 iscsi Standard round-robin Hi all, I've setup a ticket 20624099 for this issues as well. What I've consistently seen with my new readynas 3200 12TB is freezin...
MVC
May 28, 2013Aspirant
JIT wrote: Firmware: 4.2.22
Windows 2008 R2
iscsi
Hi all,
I've setup a ticket 20624099 for this issues as well. What I've consistently seen with my new readynas 3200 12TB is freezing when we try and do heavy writes to it. I've had to have remote hands restart it twice, corrupting some volumes.
If it sit there and is rarely accessed or ready heavily, It doesn't lock up. There isnt anything wrong in the logs, so i'm at a loss.
Hey Jit,
Any update on this issue? When I got my ReadyNas 3200 unit a bit over a year ago I had this same exactly issue with two Win 2008 servers using a CSV with a iSCSI lun. Level 3 support eventually replaced my unit but can only guess that the drives were bad (they were going out rapidly an some of the drives had bad firmware which caused the smart errors to read in the millions). Now fast forward to now, I upgraded my host servers to 2012 and I started getting the same issue with the readynas locking up. It first happened when I tried to use the Replicate software to replicate the Luns to a second 3200. Level 2 support had no clue with my logs. I played around with my switch and NIC configuration making sure to turn on flow control, jumbo frames, separated the iscsi connections...and it lasted a week. All of the sudden over the weekend, the 3200 locked up and became unresponsive again. I added in the adapter dual NIC card thinking maybe spreading the bandwidth among 4 NICS instead of 2 on the NAS might help, it didn't. The unit locked up again. Finally I decided to ditch the CSV and moved all the VMs on to the local hosts and just used the NAS for file storage. Again it locked up.
I am ready to throw this unit out the window and really regret buying a second one for replication. Level 2 support seems to be clueless with the logs and they always make it so hard to escalate things to level 3.
Anyone else seeing the same thing? I asked around some of my buddies using other NAS/SAN devices, they never experienced lockups.
