AndB39it
Mar 03, 2022Aspirant
ReadyNAS 3220 6.10.6 very slow web UI
Hi, on a 3220 with 6.10.6 not used in production, after a while i went to its web interface, and found it very very slow, but all seems to be reported healthy by various tools, as Raidar 6.5. I tri...
Mar 03, 2022Guru - Experienced User
AndB39it wrote:
Hi,
SSH is enabled and i can login with root and admin user password.
the evidence is that any portion of web ui takes a lot to render, with classic wheel spinning.
Are you seeing any unusual activity with top?
What services are enabled? (including file search, and AV).
AndB39it
No, i did not see unusual activities in "top";
it seemed that from opening web ui, login and wait for first content finish to display, rarely any process went to above 1-2%
AV and file search are OFF (disabled).
Thank you and regards.
Andrea
