AndB39it
Mar 03, 2022Aspirant
ReadyNAS 3220 6.10.6 very slow web UI
Hi, on a 3220 with 6.10.6 not used in production, after a while i went to its web interface, and found it very very slow, but all seems to be reported healthy by various tools, as Raidar 6.5. I tri...
AndB39it
No, i did not see unusual activities in "top";
it seemed that from opening web ui, login and wait for first content finish to display, rarely any process went to above 1-2%
AV and file search are OFF (disabled).
Thank you and regards.
Andrea
AndB39it
Mar 04, 2022Aspirant
AndB39it wrote:No, i did not see unusual activities in "top";
Andrea
Could it be because space left is less than 20% (i don't think so)
or RAM error issues? how for example troubleshoot RAM errors or network interfaces issues?
regards.
Andrea B.
- AndB39itMar 16, 2022Aspirant
I removed one disk (pulled out from chassis) that showed several errors/warnings (in SMART stats i think), but was reported as healthy (green) overall, and web ui is a lot more responsive now.
At this moment i did not reinsert same disk or substituted it with new disk (volume is reported as degradet, but it is RAID6).
I must say that another disk has several SMART errors/warnings, but removed and reiserted before the one above did not change ui responsiveness.
I will let know after disk replacement.
Andrea B.
